starbrightsteve Posted July 17, 2014 Share Posted July 17, 2014 I have found in my 86 Sunrader, that all the propane lines and tee connectors run inside the coach. I am considering running a new distribution line under the floor (outside) and installing all the tee's that serve each appliance outside on the new line. Have any folks already done this modification? It will move 4 potential gas leakage sites outside of the coach. Quote Link to comment Share on other sites More sharing options...
jdfrost64 Posted July 17, 2014 Share Posted July 17, 2014 my sunland has all lp lines running outside Quote Link to comment Share on other sites More sharing options...
WME Posted July 17, 2014 Share Posted July 17, 2014 Mine are out side and the piping is all black iron pipe.The actual T has a fitting to reduce the line to copper tubing to the appliance. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted July 17, 2014 Share Posted July 17, 2014 I can't say I remember anyone ever going to the trouble of redoing their piping. And mention of propane leaks is pretty rare and seem to be most commonly caused by things attached to the piping and not the piping itself. Quote Link to comment Share on other sites More sharing options...
zero Posted July 17, 2014 Share Posted July 17, 2014 I have found in my 86 Sunrader, that all the propane lines and tee connectors run inside the coach. I am considering running a new distribution line under the floor (outside) and installing all the tee's that serve each appliance outside on the new line. Have any folks already done this modification? It will move 4 potential gas leakage sites outside of the coach. My Chinook has most of them inside, whereas my Minicruiser has all the main lines outside. Considering your propane systems runs at very low pressure - approx 1/2 PSI - the prospect of a leak from a pipe isn't a big worry to me. When the pipes are inside - they are much less likely to rot or corrode and if there IS a leak - you'll smell it a lot faster. My Minicrusier outside LP pipes are black iron and brass which is not a great combo when exposed to rain, road salt, snow, etc. Quote Link to comment Share on other sites More sharing options...
