Tressa Posted June 7, 2014 Share Posted June 7, 2014 I have a 1986 Toyota New Horizon that wouldn't hold water. The water pump would run when turned on but no water would come out. I would fill the tank but the water would leak under the cab and run out from underside of the rig. I hired a mechanic/handyman to fix the problem. He had to remove the table from the wall and unscrew the chair. He tore out the carpet and unscrewed the screws that was holding the board down. Then he inspected the tank. The water tank holds 24 gallons of water. He disconnected the wires and took it outside to check for leaks, It didn't have any leaks. The water pump itself was working okay cycling on and off as it should. The trouble was with the water regulator. All the gaskets were rotted out and was sucking air. Once he removed the water pressure regulator and hooked the wires back up to the tank all is working again! I have running water! Thanks, Mike. Having running water is a luxury. Quote Link to comment Share on other sites More sharing options...
Maineah Posted June 8, 2014 Share Posted June 8, 2014 Well some might call it a necessity! Glad you got it fixed running water is a good thing. Quote Link to comment Share on other sites More sharing options...
