waxman Posted November 27, 2013 Share Posted November 27, 2013 My drain in the shower real slow. How is the metal drain top removed. Is it glued in or screwed on. Thanks for your advice. Quote Link to comment Share on other sites More sharing options...
5Toyota Posted November 29, 2013 Share Posted November 29, 2013 soory i need to know that myself same problem Quote Link to comment Share on other sites More sharing options...
Riverman77 Posted November 30, 2013 Share Posted November 30, 2013 My drain in the shower real slow. How is the metal drain top removed. Is it glued in or screwed on. Thanks for your advice. Waxman, I re-sealed my metal drain assembly, a couple of years ago (88 Dolphin). If I remember correctly, the nut in the access panel simply pulled the metal drain straight down. It was a two man operation - one inside the shower and the other outside turning wrenches in the access panel. Ordinarily, I'd use plumbers putty. But for some reason, we chose to cheat and used a bead of silicone instead. Mine hasn't leaked since. Hope that helps you. ~Riverman77 Quote Link to comment Share on other sites More sharing options...
