smokepolehall Posted July 30, 2007 Share Posted July 30, 2007 Yes thats right cutting all that rotted junk off. I measured at entry door below gas cap. Then drew my cutoff line along side of coach. Its even with level of wheelwells! Have both sides ready to go and start cutting! Between this and removing coolant/hot water heater setup. i should remove about 45-50 lbs. Plus the weight i remove from ladder and luggage rack, maybe i get lucky and lose 65/70 lbs. of unneeded weight. Quote Link to comment Share on other sites More sharing options...
smokepolehall Posted August 1, 2007 Author Share Posted August 1, 2007 I have cut off the passenger side alum. skin and bulkhead below the frame and even with the wheelwell. I also got all of the rotted wood out and the wood staples. I came in at 12:30 pm has gotton to hot fer me out there. Mid to high 90's and 80percent humidity! Quote Link to comment Share on other sites More sharing options...
smokepolehall Posted August 2, 2007 Author Share Posted August 2, 2007 I went out just abit ago and cut all the drivers side junk off. The lower part of the alum.skin itself is oxydized in places that it just crumbles! Not a real good sign. Quote Link to comment Share on other sites More sharing options...
