Debbit Posted August 9, 2013 Share Posted August 9, 2013 Well, got the water sorted out. New fittings, bathroom faucet and capping off the toilet line until I can afford a new toilet. No leaks. Water is flowing where it is supposed to now, and carpet iS drying out. But when I turn off all the faucets, the pump just keeps running. My battery is good, had it tested. So I turn the switch on the wall on and off to use water. Typical of an 84 dolphin 300? I've got the manual, and it says the pump should go off by itself. Quote Link to comment Share on other sites More sharing options...
waiter Posted August 10, 2013 Share Posted August 10, 2013 It should turn off when the pressure builds up, but these are known for flaky pressure switches.. Does it sound like its bogging down when all the water is off? AND, I assume your pumping water from your tank and you don't have the city water hooked up.Mine has had a bad pressure switch since I bought it. We just got in the habbit of turning the pump on and off when we need it. JOhn Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
Debbit Posted August 10, 2013 Author Share Posted August 10, 2013 Ok, that's what it sounds like. Yes, pumping from fresh. It won't be too much trouble to just turn it on when we want water. At least till we decide to get a new pump. Thanks! Quote Link to comment Share on other sites More sharing options...
waiter Posted August 10, 2013 Share Posted August 10, 2013 Karin, tnks, I didn't know they had re-build kits for the pump. I'll need to look into doing that with mine.John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
Maineah Posted August 10, 2013 Share Posted August 10, 2013 Yeah you can even buy the diaphragm and the valves too. A lot of the older ones had a standard issue micro switch. Quote Link to comment Share on other sites More sharing options...
