smokepolehall Posted July 17, 2007 Share Posted July 17, 2007 I opened a can of worms repairing the rear bulkhead. Found badly rotted flooring and wood strips plus alum. has dropped below most of the framing. Odd Duck was just shoddy built, some spots under coach are over 2' without any support under the 3/8" ply. the bulkhead sides have pulled away from flooring. I was thinking of putting 1/8" alum. angle 1"x1 1/2" the outside edge of flooring and in between all the bigger open spots to support flooring. Anyone have any input of good ideas and materials? Both sides from behind axle are completely rotted, should i cut off all of that stuff and just tuck few inches of alum. skin under frame? The gray and black water tanks will show abit on the outside, but won't stop them from working. Any input on that pos or neg. i can roll with the flow. Some of y'all mayhave lots more wisdom and been thru this rebuilding process! Quote Link to comment Share on other sites More sharing options...
