dwavetman Posted July 12, 2007 Share Posted July 12, 2007 My husband and I recently purchased a 1987 21' Sunrader. Our first RV. It has the standard air on top; propane fridge and stove. We thought it good that it only had 38,900 miles on it. When we read Turbo Greg's post, we are now thinking we are "babes in the woods" about this unit. The only two things we noticed: It looks like someone did something to the fender where the gas tank was. We bought this from a dealer, who bought it at an auction, and he didn't know what had been done. Suspect something to do with the gas tank. And a little rust where the water heater is lit. (How do you fix that?) Otherwise it's a very clean vehicle, but seems to be rather underpowered going up hills. Only a 4 cyl. Does anyone know of someone in the Sacramento area who is knowledgeable about how to give it more power. Thank you. Quote Link to comment Share on other sites More sharing options...
turtle Posted July 12, 2007 Share Posted July 12, 2007 And a little rust where the water heater is lit. (How do you fix that?)seems to be rather underpowered going up hills. Only a 4 cyl. Does anyone know of someone in the Sacramento area who is knowledgeable about how to give it more power. Rust around the burner is "normal" and nothing to worry about. The heat from the burner will cause the metal to be more susceptible to rusting. Pull the drain plug out and if no rust comes out of the tank you are fine... A 4 banger on a long coach is a real stretch for power. There was a thread not to long ago about now to squeeze a few more HP out of an R22 http://www.toyotamotorhome.org/forums/inde...p?showtopic=595 Just about everything possible that could be done to an R22 was discussed Quote Link to comment Share on other sites More sharing options...
smokepolehall Posted July 14, 2007 Share Posted July 14, 2007 Don't know any thing about a sunrader, know little about the 4 cyl. Mine has 4 spd. slow maybe, but that is why we got it. To look at the country side as we travel about. I don't know how fast ours will go, only have driven it one time from where we got it. I know it will do 55 mph and thats really fast enough and too fast to look at country. Quote Link to comment Share on other sites More sharing options...
