smokepolehall Posted June 29, 2007 Share Posted June 29, 2007 Does anyone know if this setup would be ok under the Toy MH? I could use Cont. vanco8's 205/75/14, they have 2200 lb. load rating. Thats 4400 lbs. for the rear. I have found a good many complete rearends reasonably priced. The dually setup they all want $450 and higher! Plus shipping! Quote Link to comment Share on other sites More sharing options...
bufbooth Posted July 11, 2007 Share Posted July 11, 2007 One concern I have is that if you go with a single tire setup, a blowout would be more dangerous than if you had one tire blowout on a duelly setup. Also, are you sure 4400 lbs is enough? My tires (185/75/14) have a rating of 1700 lbs, which gives me 6800 lbs (1700 x 4), about 55% more capacity than your single tire setup. My concern is that with 4400 lbs, you might be close to your max. capacity instead of at a working capacity. If one of your tires ends up under inflated, it is a +90 degree day, you end up slightly overloading the RV, you could be on or over the capacity line. Dennis... Quote Link to comment Share on other sites More sharing options...
smokepolehall Posted July 15, 2007 Author Share Posted July 15, 2007 I will have to weigh my Odd Duck and see how much it weighs empty. Hopefully no ore than 3600 lbs. Its 17' long, i am worried about the 5 lug dual wheels putting too much pressure on bearings. I may end up having to save up $ 600 fer and get a used 6 lug complete with wheels and tires. I know where a 6 lug is but it only has single wheels on it, i reckon i could find some dual wheels fer it. Quote Link to comment Share on other sites More sharing options...
turtle Posted July 15, 2007 Share Posted July 15, 2007 I know where a 6 lug is but it only has single wheels on it, i reckon i could find some dual wheels fer it. Be careful that you don't get a 4x4 rear end. They are 6 lug but NOT 1 ton Quote Link to comment Share on other sites More sharing options...
smokepolehall Posted July 15, 2007 Author Share Posted July 15, 2007 The salvage yard owner said it was a 6 lug 1 ton truck with complete rearend setup but only had single wheels up under it. Front end is totaled, its an 1988 and has 4.30 gear ratio. He said it was a 2wd, its only 82 miles and he wants $151.00 fer it. Guess it would be worth a run over there to check it out. i could take my 4x8 trailer and 4 ratchet straps just in case it was the real thing. Closest other setup is Toy MH rearend 6 lug out of Fl. for $450 plus shipping. I'd have to call and make sure its complete setup. Quote Link to comment Share on other sites More sharing options...
turtle Posted July 15, 2007 Share Posted July 15, 2007 The salvage yard owner said it was a 6 lug 1 ton truck its only 82 miles and he wants $151.00 fer it. Guess it would be worth a run over there That's about the price of the 2 rims by themselves Try to get the springs and the parking brake cables also. Lower gearing is another xtra on that one as normal would be 410:1 or 390:1 There was a fellow selling 1 ton rims on eBay not too long ago. I talked with him and he had several of them. They're not pretty but nothing a little paint wouldn't clear up. I'm all set with 14 for the 2 toys (7 on each) http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=200126708329 Quote Link to comment Share on other sites More sharing options...
