ted.thurlby Posted April 18, 2013 Share Posted April 18, 2013 Follow up on the Install of the Temperature Gage. Instead of using the manifold to splice into the tubing I went over to a friends house and he installed a fitting to the oil pan. He brazed a 1/4 pipe fitting onto the trans pan. There is only one place to put this due to the valve body that takes up almost the whole pan area. It is possible to install the temp probe into the pan. Tried it out and it works fine. Try to post pictures this time. I give up I cannot upload any pictures of the install. If you want the pictures send me a email and I will send them to you. Great pictures. Ted from Seattle Quote Link to comment Share on other sites More sharing options...
