just getting an idea of how much propane gas i will be buying.
i plan on going full time in a few months.
i will probable use it for a total of 2hrs a day. and i think its a 5 gallon tank.
thanks
Marco, you can compute and plan your usage if you do a small amount of research.
A 5 gallon tank (typical BBQ tank) is 20 lbs. 1lb of propane can supply about 21,000 BTU, so a full tank should be able to supply 21,000 x 20 = 420,000 BTU
i.e what appliances will you be using, and for how long. These number are estimated BTUs per hour
Stove burner = 7,500 BTU
Frig = 400 BTU
Furnace = 16,000 BTU
Mr Buddy heater = 3,000 / 9,000 BTU
NOTE - Your furnace is probably about 50% efficient, so even though your consuming 16,000 BTU, about 8,000 heats the house, and 8,000 heats the outside world. The Mr Buddy is 99.9% efficient, all the heat it produces heats the house.
EXAMPLE - I just returned from a road trip, 1 tank (20 lbs) lasted just over a week. we ran the frig continuous for the 8 days (77,000BTU). we ran the Mr Buddy about 8 hours a couple nights on 3,000 and 4-5 nights on 9,000.
John Mc
88 Dolphin 4 Auto
Don't forget to throw the water heater in there too. I don't live in mine and use 6 or 7 gallons a season May to Nov. so an outing any where from 2 days to 2 weeks 5 or so times a year. As waiter pointed out your energy hog is going to be the heater go some where warm!
OPS, Forgot about the water heater... Looks like about 12,000 BTU.
John Mc
88 Dolphin 4 Auto
A propane tank should not be filled more than 80%, so at best you have 18lbs, or less to start you trip.
