HUntsman Posted December 17, 2012 Share Posted December 17, 2012 (edited) confused as to how many upper control arm bushings there are in front end of pickup is it 1 per side = 2 or are there 2 per side = 4 ? (almost certain this is correct) --also, how many ball joints do these bad boys take thanks 22R--4cyl -RWD Edited December 17, 2012 by HUntsman Quote Link to comment Share on other sites More sharing options...
zero Posted December 17, 2012 Share Posted December 17, 2012 1982 - on each side there are two upper control-arm bushings, one lower control-arm bushing, one upper ball joint and one lower ball joint. So the entire front end has 6 control-arm bushings and 4 ball joints. Older trucks like a 1978 have 8 control-arm bushings and 4 ball joints. Quote Link to comment Share on other sites More sharing options...
HUntsman Posted December 17, 2012 Author Share Posted December 17, 2012 1982 - on each side there are two upper control-arm bushings, one lower control-arm bushing, one upper ball joint and one lower ball joint. So the entire front end has 6 control-arm bushings and 4 ball joints. Older trucks like a 1978 have 8 control-arm bushings and 4 ball joints. u the man . thanks Quote Link to comment Share on other sites More sharing options...
