guitarlover519 Posted March 13, 2012 Share Posted March 13, 2012 Trying to figure out where to go with this thing. Since my cab heat isnt blowing warm, the guy I bought the Sun Land from fired up the furnace which opporated fine for about two hours then blew out on the way home.. Of course this seemed normal because it was quite windy. So I fired it up yesterday and it ran for about 2 minutes then just blew cold air. Shut it off and shut it back on 45 seconds later and it didnt even attempt to ignite... Thats as far as i have gone with it as it was getting late. Any ideas? im thinking the gas pressure may have some bubbles since it was recently filled and not run in a bit? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted March 13, 2012 Share Posted March 13, 2012 Do your stove burners work OK? Quote Link to comment Share on other sites More sharing options...
guitarlover519 Posted March 13, 2012 Author Share Posted March 13, 2012 stove burners work fine. the oven gas pressure is low though. Quote Link to comment Share on other sites More sharing options...
Dolphinite no longer here Posted March 13, 2012 Share Posted March 13, 2012 Sounds like your coach battery is low. Start up the engine and see if the furnace will fire up. If it does, you should check out the coach battery and see if its good. John Quote Link to comment Share on other sites More sharing options...
