mccrosti Posted August 13, 2004 Share Posted August 13, 2004 Howdy All, Just got a bug and found a Sunland model of these mini motorhomes. Can anybody fill me in or comment on Good/Bad, things to wtach out for. Just looking for advice. Thanks! Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted August 14, 2004 Share Posted August 14, 2004 I don't know much about the Sunland models. All Toys have related things to look for. The biggest is the rear axle. If your rig is 1997 or newer you may have the bad axle. In the forum here look at the engines and transmissions section. Look at the axle facts thread, there you will find a link to some of the best information about the bad and good axles. Water damage and leaks are another problem as with all RV's. Once a coach starts to have internal rot its a big problem and difficult to repair. Water stians on the inside are tell tales but not allways visible. Transmissions are the other big concern. They tend to run hot because of the load on them. Most everyone feels ots best not to use overdrive. Having a complete fluid change is benificial. A machine is hooked up and as the old flows out the new flows in. If its never been done it should be. I plan to have mine done soon. I may be the only toy motorhome owner though that has a A340H transmission. I also have a temp gauge on the tranny and can see that the temps can get up in the high 280's. These temps destroy the fluid, end result the tranny blows up at some point. Greg Quote Link to comment Share on other sites More sharing options...
mccrosti Posted August 15, 2004 Author Share Posted August 15, 2004 Greg., As expected. I have had a Toy.P.U. and had 211,000 miles on her when I sold. Great little motors, sort of like a mini-chevy. I am just gonna have to go over and check this thing out thoroughly. Dave Quote Link to comment Share on other sites More sharing options...
