Kensandiego Posted May 28, 2011 Share Posted May 28, 2011 Hi All, Had the tv plugged into a new inverter in the rear 12v cigarette socket, worked great for a while then socket stopped working. I can't find the fuse to check, any ideas? I opened the outlet and the fuse there was good. I plugged other items in the socket and it just does not work. Thanks Ken Quote Link to comment Share on other sites More sharing options...
bufbooth Posted June 13, 2011 Share Posted June 13, 2011 Hello Ken, The 12 volt fuse should be under a metal panel/door in your 120v curcuit breaker box. The panel/door is probably secured with one or two screws, under it you should find two or three in-line glass 12 volt fuses. Dennis B. Hi All, Had the tv plugged into a new inverter in the rear 12v cigarette socket, worked great for a while then socket stopped working. I can't find the fuse to check, any ideas? I opened the outlet and the fuse there was good. I plugged other items in the socket and it just does not work. Thanks Ken Quote Link to comment Share on other sites More sharing options...
waiter Posted June 13, 2011 Share Posted June 13, 2011 On my Dolphin, there are two fuses mounted on the battery box (under the aft bench seat). One fuse is for the Battery and the other fuse is for the Cig lighter. NOTE - This photo shows how I mounted my 1500 watt inverter. however, I circled the location of the battery and Cig lighter fuses. You can get to it either through the compartment door, or remove the seat cushions and reach inside an pop the plywood piece out that makes up the seat bottom. John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
