pdqmovie Posted May 14, 2011 Share Posted May 14, 2011 Hi there , I bought my self a 1975 honda trail 90 it about 200 pounds can i be able to put it behind the Toyota motor home so i can run errands or to the market when i am at a camp site ?? i was giving a rack with the honda because it was on the old owners rv that was not a toyota . If not on the back have anybody have a motocycle in the front of the rv ??? I was thinking it would be hard to see to drive but i am open to ideas Quote Link to comment Share on other sites More sharing options...
pdqmovie Posted May 14, 2011 Author Share Posted May 14, 2011 this is what i was looking for the front bumper on the toyota to hold the trail bike http://www.motorcycle-superstore.com/2/9/206/4583/ITEM/EPCO-Cycle-Carrier.aspx Quote Link to comment Share on other sites More sharing options...
86rader Posted May 14, 2011 Share Posted May 14, 2011 With a properly reinforced bumper, you could hang it out back. Personally, I think a lightweight trailer is a better option. Quote Link to comment Share on other sites More sharing options...
Lee & Joan Posted May 17, 2011 Share Posted May 17, 2011 After reading up (here) on the leverage placed on the wimpy rear frame behind the axle and having a good look underneith the frame. I decided that reinforceing the frame was going to be complicated and not very effective. I am carrying a 250 # Honda 250, but a 195# Honda 90 would do the same thing. So I took some good advice from here and welded a 2" reciever on the rear and went with a trailer. I got a nice Harbor Freight 4' X 8' 1700 # frame with 6 ply tires and 5 bolt rims. It is on sale for $375 but with the 20% off coupon was $311. I am putting a 4X8 sheet of expanded metal on for a floor and plan to load the trailer so the tounge weight is on the light side. My big hangup on doing this was backing up so I got a $70 Peak 7" backup mirror/ camera AND A SET OF $12 halogen backup lights wired into the reverse circuit. I know myself well enough to know I will need to be backing into some backwoods parking spot at O'Dark Thirty... Quote Link to comment Share on other sites More sharing options...
ILIA Posted May 18, 2011 Share Posted May 18, 2011 The frame can handle the draw from a 1,000 pound trailer easily and stress from hitting the brakes, but definitely not tongue weight over 150 pounds. With a trailer my tongue weight almost never even came close to exceeding 80 pounds and I slept better knowing there wasn't as much stress on the rear. Plus beefing up the rear can add a lot of weight. 100 pound for sure if done properly. And as for the front the coach manufacturers stressed never to drive with weight in the overhead bunk due the handling while taking turns. I couldn't imagine driving with a trail bike mounted on the front. Get the hitch and trailer or just get a bicycle. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted May 18, 2011 Share Posted May 18, 2011 I came across the following, which is kind of interesting and seems to explain things clearly:- http://www.transport...vehtowguide.pdf Notes from the Pdf above:- - You should not exceed manufacturer's GVWR; - You should not exceed manufacturer's GAWR; - Adding components such as air bags or overload springs does not allow these rating to be increased or exceeded. I've never come across a good list of GVWR, GAWR, GCWR for the different years of Toyota Motorhomes. I know the GVWR went from 5300lb to 5500lb (22RE, 1-Ton) to 6000lb (V6). GCWR reached 8500lb (V6?) 'when properly equipped'.Attached are specs for the '86 Winnie. Notice how close to being overloaded the front axle is. Quote Link to comment Share on other sites More sharing options...
bufbooth Posted May 23, 2011 Share Posted May 23, 2011 Here is a very light weigth single motorcycle trailer. There are a few companies making these. http://trailerinabag.com/products.html Quote Link to comment Share on other sites More sharing options...
