toycoach Posted December 20, 2010 Share Posted December 20, 2010 My 1986 Coachman with the rear dinette has a water leak that only occurs when we use the shower. The carpet in front of the commode is soaked. Any ideas on how to begin to find the cause of the leak or how do you get under the shower pan to check this out. Have already had leaks in the tubing going to the shower in the wall repaired. I do not think that the commode is leaking but that could be the problem, just know it only seems to occur when we shower. Any ideas appreciated. Quote Link to comment Share on other sites More sharing options...
Maineah Posted December 22, 2010 Share Posted December 22, 2010 Check your water heater. I'm not sure where it is on yours but they get small holes in them and get worse when they heat up if it's some where near the wet spot it's suspect. Quote Link to comment Share on other sites More sharing options...
