cabinguy Posted December 14, 2010 Share Posted December 14, 2010 (edited) There are several postings about folks that have done this overide, but no one comes right out and spells it out. At least I can't find where anyone has. I have an 86 Dolphin with auto tranny, and of coarse if has done the no OD above 4k feet. I live above that number, so would like to know how this is actually done. Thanks in advance to anyone that can outline this for me. Edited December 14, 2010 by cabinguy Quote Link to comment Share on other sites More sharing options...
cabinguy Posted December 26, 2010 Author Share Posted December 26, 2010 There are several postings about folks that have done this overide, but no one comes right out and spells it out. At least I can't find where anyone has. I have an 86 Dolphin with auto tranny, and of coarse if has done the no OD above 4k feet. I live above that number, so would like to know how this is actually done. Thanks in advance to anyone that can outline this for me. Found the answer, unplug the transmission relay and run a jump wire with a switch in it, between the 2 terminals where the realy was. It's the two that are opposite each other, overdrive working fine now. Quote Link to comment Share on other sites More sharing options...
cabinguy Posted December 26, 2010 Author Share Posted December 26, 2010 See origianl posting, answere to problem is in it. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted December 26, 2010 Share Posted December 26, 2010 Thanks for taking the time to post your solution. Could you add info on where the relay is located? Thanks again. Quote Link to comment Share on other sites More sharing options...
cabinguy Posted January 4, 2011 Author Share Posted January 4, 2011 The relay is located on the housing right next to the brake pedal, it is on the part of the bracket that would mount the clutch pedal if it were a standard transmission. Hard to miss it, mine is blue in color and it even says transmission relay on it{after you dismount it from mentioned bracket you'll see it printed on the side} Is three wires going to it. Thanks for taking the time to post your solution. Could you add info on where the relay is located? Thanks again. Quote Link to comment Share on other sites More sharing options...
