gene j Posted July 14, 2010 Share Posted July 14, 2010 I was thinking of removing my fridge and doing some bench work on it but wasn't sure how difficult it would be. Looking in the access panel I can see you would have to unplug electric and disconnect gas line. There are two screws in the rear on the runners that go into the wooden base that I see when looking in from the outside access panel. After that I'm not sure what else would have to be done. Are there more than the two screws I see from the back? If anyone has any insight on this I would certainly appreciate it. I had forgotten about the vent to the roof. Is that very difficult to deal with? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted July 14, 2010 Share Posted July 14, 2010 Have you got a copy of the Installation Manual? I'd think you'd find some useful clues in there. Not knowing the model you have, I haven't looked too hard online. But this might be it:- http://gasrefrigerat...2300_2800OP.PDF There might be useful info here, too:- http://cabbieland.by...frigerator.html Quote Link to comment Share on other sites More sharing options...
gene j Posted July 15, 2010 Author Share Posted July 15, 2010 Have you got a copy of the Installation Manual? I'd think you'd find some useful clues in there. Not knowing the model you have, I haven't looked too hard online. But this might be it:- http://gasrefrigerat...2300_2800OP.PDF There might be useful info here, too:- http://cabbieland.by...frigerator.html Thanks Derek, Those links are helpful and I'll give it a shot. If I run into any big problems I'll post again. Again, thanks. Gene Quote Link to comment Share on other sites More sharing options...
