motoyhomme Posted June 2, 2010 Share Posted June 2, 2010 A few weeks ago, my 83 Sunrader 22R 4 spd manual started missing under load. I finally found the time this weekend to do it's first tune-up since I bought it 5 years ago. It always ran smooth and plenty of power so I didn't touch it, other than valve adjustment. The PO always took it to an independent shop to have it serviced regularly. Anyway, I bought plugs, distributor cap, plug wires and rotor button and started to pull the plugs. Plug number 1 had loosened up by itself enough that it was losing compression, same with plug 2. Plug 3 was loose. Plug 4 was so tight, I had to use penetrating oil to remove it. Installed 4 new plugs with anti-seize compound and torqued them correctly and installed all of the other new items. Runs like a jewel again. I brought this up just in case someone else has the same symptoms: loss of power, cutting out almost like it was having fuel starvation. Check your plugs! Allen Quote Link to comment Share on other sites More sharing options...
Maineah Posted June 2, 2010 Share Posted June 2, 2010 Thanks I wish every one would post an answer to a problem they found after submitting it we all can learn from that. Quote Link to comment Share on other sites More sharing options...
leshok Posted July 5, 2010 Share Posted July 5, 2010 Coming home from our last show we are were having the exact same problem with our motor home. Thanks for the post! Quote Link to comment Share on other sites More sharing options...
