bufbooth Posted January 29, 2010 Share Posted January 29, 2010 Hello All, I have a slight leak with my propane tank where the regulator hooks up to the tank. Should there be a rubber gasket on the receiver on the tank? If so, where would one purchase a gasket for it (camperworld?). Thanks, Dennis... Quote Link to comment Share on other sites More sharing options...
Maineah Posted January 30, 2010 Share Posted January 30, 2010 I guess you are talking about the bull nose that fits in the tank valve end. The older ones did not have a gasket but the new ones have a small "O" ring either will work. So maybe if you can't get the old one to seal you could try a newer bull nose with the "O" ring they do unscrew from the regulator. I was looking for a propane fitting and found what I wanted on line I think I found it under "propane brass fittings" Quote Link to comment Share on other sites More sharing options...
Maineah Posted January 30, 2010 Share Posted January 30, 2010 Found one http://www.bigway.com/CARTgallery2.htm (I was looking for a female pol) Quote Link to comment Share on other sites More sharing options...
