bobf2175 Posted August 26, 2009 Share Posted August 26, 2009 I am looking to replace all of my lug nuts and having a hard time finding them..23mm hex head 14mm x 1.50 chrome. Thank you for any help bob Quote Link to comment Share on other sites More sharing options...
turtle Posted August 26, 2009 Share Posted August 26, 2009 Have you tried Toyota? I have had good luck getting discounted parts from this dealer in Michigan http://www.toyotapart.com/default.asp Give them a shout (800-681-3033) and get OEM replacement lug nuts for about what over the counter Chinese ones will cost you Quote Link to comment Share on other sites More sharing options...
jpyzik Posted September 3, 2009 Share Posted September 3, 2009 I am looking to replace all of my lug nuts and having a hard time finding them..23mm hex head 14mm x 1.50 chrome. Thank you for any help bob Remember when you order them that the driver side may be left handed threads Quote Link to comment Share on other sites More sharing options...
turtle Posted September 4, 2009 Share Posted September 4, 2009 Remember when you order them that the driver side may be left handed threads Only if the rear axle was manufactured in 1985 Quote Link to comment Share on other sites More sharing options...
powdrhound Posted September 30, 2009 Share Posted September 30, 2009 I had no problem getting left-hand nuts and studs from Toyota for my 1986. But not chrome. Quote Link to comment Share on other sites More sharing options...
scottperkins Posted September 30, 2009 Share Posted September 30, 2009 You have given me an idea. I never knew what the thread pitch and spacing was but if the 14mm x 1.50 is correct I am going to try to find other larger lug nuts of a more standard size than 23 mm and replace all of mine. Also important is the shape of the bottom of the lug nut where it contacts the wheel. Actually a 15/16ths deep six point socket will work pretty well on 23mm lug nuts and it not a terrible fit if you did not know. Yes, there is slightly more wiggle with the 15/16 as it is .032" larger but with a six point "deep" socket, it is not a worry. Dont get me wrong, the 23mm socket is what is needed, I only mention this in case of emergency. Scott Quote Link to comment Share on other sites More sharing options...
