85' - gray tank with football size hole
GR-MI-Ken
Ken,
pulled up several sites for new tanks on google
this one looked good.
http://www.watertanks.com/category/16/
this one too (but seemed pretty large)
http://www.pplmotorhomes.com/parts/waste-t...Holding%20Tanks
The only "used" holding tanks I've seen so far online are the portable ones.
Maybe someone else on this forum has some better references.
best of luck.
shanda
well, when I called the local RV shop, I got the to fax me the page from their supplier.
and it was full of things I could search the web for.
Icon Technologies Limited,
http://www.icontechltd.com/productcart/pc/...tting-34p88.htm
Best I could find was:
HT706-ED : Center End Drain Holding Tank : 15 Gal : 3" Spigot fitting
$117 - verse the $175 they quoted me
Thanks for looking for me.
Ken
If it's ABS, a plastic welder could weld a permenent patch over that for you, but it would likely cost as much as the tank.
Clarification: I am not talking about the Devcon epoxy product sold in stores called "Plastic Welder" - I am talking about a skilled guy with a hot nitrogen jet and plastic filler rod.
