yoyoman Posted July 1, 2009 Share Posted July 1, 2009 Hi - I see water that is coming in and dampening the cardboard that surrounds the lpg unit. If I am correct, this is where the water heater and gas controls are, just behind the drivers door, on my 1979 Sunrader. When I lift up the couch cushion and seating board, I see the wet-ish cardboard, and I can see from the outside that the water dripping from the window above is going right into a crack in the old, weathered rubber seal that surround the metal lpg casing? thing? I take off the vented metal outside plate and see all the knobs and valves, etc., for the water heater? So then I remove the square indented screws (about 10-12 of them) and try to pull the metal part out, but it wont remove, I think because its attached to the back gas lines, etc. What do I have to remove from under the couch seat so that I can pry off the metal housing of the lpg unit? Thanks!! :0) Quote Link to comment Share on other sites More sharing options...
Bodybagger Posted July 2, 2009 Share Posted July 2, 2009 I think you'll have to disconnect the gas lines and uncrew a few screws that are holding it to the floor and pull it out as one whole unit. Quote Link to comment Share on other sites More sharing options...
yoyoman Posted July 2, 2009 Author Share Posted July 2, 2009 Super thanks! I appreciate the instruction, Bodybagger. Quote Link to comment Share on other sites More sharing options...
