What would a good compression test reading for my '87 Sunrader 4 cyl engine be?
Thanks,
Iflyfishunderpressure
Toyota 22r compression specs, warm engine
Nominal 170 psi
Minimum  142 psi
Max variation between high and low cylinder 14 psi
Remove ALL the sparkplugs, block the throttle wide open, EFI? remove the fuel pump fuse. Then do the compression check.
If the readings are low, a couple squirts of oil in each cylinder, one at a time and then bump the start for a few revs. Recheck compression, if still low, suspect bad valves. If the readings jump up to normal, suspect bad rings
Edited by WME
Nominal 170 psi
Minimum  142 psi
Thank you very much! Very helpful! Have a good one
Iflyfishrelieved
