buick Posted February 17, 2009 Share Posted February 17, 2009 I have a 89 sunrader with a crack in the front wrap around window. I found a used one here in town but they said they dont have the gasket for it. Does anyone here have step by step instructions for the removal and install of the window and gasket? -john Quote Link to comment Share on other sites More sharing options...
turtle Posted February 18, 2009 Share Posted February 18, 2009 I have a 89 sunrader with a crack in the front wrap around window. I found a used one here in town but they said they dont have the gasket for it. Does anyone here have step by step instructions for the removal and install of the window and gasket?-john Have a read over of this thread http://www.toyotamotorhome.org/forums/inde...post&p=5868 and the topic a couple down will give you the name of the gasket manufacturer Quote Link to comment Share on other sites More sharing options...
buick Posted February 18, 2009 Author Share Posted February 18, 2009 Have a read over of this threadhttp://www.toyotamotorhome.org/forums/inde...post&p=5868 and the topic a couple down will give you the name of the gasket manufacturer Which gasket did you use on that site, also what is the best way to get the windows out and then in? Looks pretty complicated!! Quote Link to comment Share on other sites More sharing options...
dparsons Posted February 18, 2009 Share Posted February 18, 2009 I have a 89 sunrader with a crack in the front wrap around window. I found a used one here in town but they said they dont have the gasket for it. Does anyone here have step by step instructions for the removal and install of the window and gasket?-john I have a 1981 Sunrader and I'm looking on getting a replacement. Where did you find the window? My husband said you should be able to go to a glass shop and they would have the casket you need to replace the window. Donna Quote Link to comment Share on other sites More sharing options...
ToyoGuy Posted February 20, 2009 Share Posted February 20, 2009 I have a 89 sunrader with a crack in the front wrap around window. I found a used one here in town but they said they dont have the gasket for it. Does anyone here have step by step instructions for the removal and install of the window and gasket?-john Sorry John, late to the party, as usual. If you're still looking for de-install hints etc. I will just say that doing this is tough to do without scaffolding across the hood. Possible maybe to use 2 good sturdy ladders with a 2 x 12 (or two 2x6's stacked) pushed through steps depending on a person's weight. There is a rubber bead that can be tough to find the ends of in the center of the stock gasket for the windows, Take an awl and carefully pry out the end when you find it. See below: If it is old, it may come out in pieces. Otherwise, it can be carefully pulled out all the way around the perimeter. Once it is out, if not caulked,the gasket will fold right back into the interior. You may need a thin plastic putty knife lubricated with soapy water to separate the gasket. The window can then easily be pushed back into the overhead bunk area. The install is outlined in one of the other links before mine. BR, Toyoguy Quote Link to comment Share on other sites More sharing options...
buick Posted February 20, 2009 Author Share Posted February 20, 2009 Sorry John, late to the party, as usual. If you're still looking for de-install hints etc. I will just say that doing this is tough to do without scaffolding across the hood. Possible maybe to use 2 good sturdy ladders with a 2 x 12 (or two 2x6's stacked) pushed through steps depending on a person's weight. There is a rubber bead that can be tough to find the ends of in the center of the stock gasket for the windows, Take an awl and carefully pry out the end when you find it. See below:If it is old, it may come out in pieces. Otherwise, it can be carefully pulled out all the way around the perimeter. Once it is out, if not caulked,the gasket will fold right back into the interior. You may need a thin plastic putty knife lubricated with soapy water to separate the gasket. The window can then easily be pushed back into the overhead bunk area. The install is outlined in one of the other links before mine. BR, Toyoguy Thanks!!! Quote Link to comment Share on other sites More sharing options...
