twodog Posted October 21, 2021 Share Posted October 21, 2021 I have a 20 warrior with 3.0 engine. when I was changing brake pads, I noticed the crossmember that goes under the oil pan is not straight, and I don't know if it has been in an accident, and was bent upward of if is supposed to be that way. It appears to be touching the oil pan. I can't seem to find a pic on line that shows the crossmember. I would appreciate it greatly if someone could take a look under theirs and let me know. Thanks so much. This site has been great in helping me with everything. Quote Link to comment Share on other sites More sharing options...
Ctgriffi Posted October 21, 2021 Share Posted October 21, 2021 Yeah, yours has got a pretty good tweak in it. Should be straight, with about 1/2" clearance between crossmember and oil pan. Since you've already got it unbolted, might be a great time to source a JY replacement (and front end alignment probably a good idea after that). Or, just live with it if it's not causing any obvious trouble 😀 Quote Link to comment Share on other sites More sharing options...
twodog Posted October 21, 2021 Author Share Posted October 21, 2021 (edited) Thanks for your help. My only concern is getting a hole in the oil pan from the crossmember rubbing it. I'll take it out, and see if I can find a replacement or try to straighten it. If anyone has one, I'd be interested. It's not available thru Toyota as far as I can tell Edited October 21, 2021 by twodog Add sentence Quote Link to comment Share on other sites More sharing options...
