Dolphin79 Posted June 29, 2020 Share Posted June 29, 2020 (edited) Having trouble figuring out what the problem is here. I had all the electricity working (off the 12v battery) and now it is not working after screwing the control panel back on. I have a brand new deep cycle battery hooked up. I removed the control panel to replace some old connectors because the wires were falling out of them and not making good contact. After that everything was still working. There was a black wire that fell out and was hanging there so I stripped it down and exposed some fresh wire and plugged it back in. I'm not sure what the problem is now but nothing is working anymore. Off the battery that is. Here are some pictures below. The water pump light doesn't come on anymore either. I'm not sure which wire that is. Anyway. All the lights on the panel still light up though. We were up north camping and I bought a new battery. I hooked it up and nothing would work. Then the next day after plugging things into outlets and flipping switches, I noticed that a ceiling light was on. This was when I decided to check the wires behind the control panel. Edited June 29, 2020 by Dolphin79 Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 29, 2020 Share Posted June 29, 2020 Here's the best I can offer:- 1993 Version 1986 Version Quote Link to comment Share on other sites More sharing options...
Dolphin79 Posted June 30, 2020 Author Share Posted June 30, 2020 Derek, Do you know what this plastic thing all the wires go into is called? That connects to the control panel? I need to buy another one and I don't know what it's called... Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 30, 2020 Share Posted June 30, 2020 Do you mean the 'plug' (white thing)? With wires attached? Can't really help you there. I'm not even sure Acu-Gage is still in business. A good complete system is this:- https://www.garnetinstruments.com/rv-shop/ Your problematic black wire appears to be the 'ground' (-) wire. Quote Link to comment Share on other sites More sharing options...
