Donegan Posted July 10, 2018 Share Posted July 10, 2018 I did a search to try and find a similar question but nothing came up. This question is about a 1988 Sunrader. The coach (lights, water pump) do not work. I have replaced the coach battery so I know it's not the battery. The battery connections are good and tight. When I plug the coach in to my house electricity, I can hear the alternator making funny noises for about 15 seconds and then nothing. There is a light that comes on in the dashboard ("CHARGE") which has never come on before when I've plugged in the coach to the house electricity. When I plug the coach into the house electricity, the coach lights/pump works. I've checked the breakers, fuses and nothing seems to be tripped or burned out. Any suggestions? Quote Link to comment Share on other sites More sharing options...
BobBeery Posted July 14, 2018 Share Posted July 14, 2018 My 94 Winnebago has a small circuit breaker in the battery compartment. It connects to the POS of the battery. If this is not connected or is tripped I get the same symptoms. Have a look. Quote Link to comment Share on other sites More sharing options...
