vrocrider Posted April 21, 2017 Share Posted April 21, 2017 I have a small area in the cab over near the roof that is damaged. Roughly 4" x 10" from the corner seam over to the center. The filon in this area has no wood backing and is laid over foam. My plan is to cut damaged filon so I have straight lines. Remove any loose foam. I'll insert epoxy and fiberglass cloth just under the Filon surface and fill any voids under cloth with spray foam from a can. I'll trace opening I have created and cut a new piece of Filon to fit in hole supported by fiberglass cloth. I'll epoxy in new Filon. Does this sound like a good plan? Suggestions? I've done some body work before but no fiberglass work. Thanks. Quote Link to comment Share on other sites More sharing options...
WME Posted April 21, 2017 Share Posted April 21, 2017 Ideas here?? http://www.delamrepair.com/index.html Quote Link to comment Share on other sites More sharing options...
