hunkaman Posted November 7, 2016 Share Posted November 7, 2016 WANTED TO SHARE THIS LITTLE PROJECT. I DECIDED TO INSTALL A FUEL COVER LOCKING HATCH ON MY 92 WARRIOR. I FOUND A HATCH COVER ON LINE THAT WAS NOT TOO BIG, BUT BIG ENOUGH. THE CHALLENGE WAS THAT THE METAL RETAINING PLATE OR COLLAR THAT HOLDS THE FILLER TUBE IN PLACE WITH SCREWS IN THE CABIN BODY IS OVAL OR ELONGATED. MOST OF THE HATCH COVERS I FOUND ONLINE WERE MORE SQUARE THAN RECTANGULAR. I FABRICATED A SPACER FROM 1/4" THICK PLASTIC AND CUT A HOLE IN IT TO MATCH THE SHAPE OF THE FILLER RETAINING PLATE AND LEFT ENOUGH OF THE PLASTIC MATERIAL ON ALL SIDES TO ACCOMMODATE THE OUTSIDE DIMENSIONS OF THE HATCH COVER. NOT WISHING TO ADD ANY MORE HOLES IN MY WINNIE, I MOUNTED THE SPACER TO THE COACH BODY WITH A 3M INDUSTRIAL STRENGTH DOUBLE SIDED TAPE THAT IS EXTREMELY THIN, THEN USED THREADED INSERTS TO MOUNT THE HATCH COVER TO THE SPACER. I FOUND SOME EPOXY SPRAY PAINT THAT CLOSELY MATCHED THE COACH AND PAINTED THE SPACER BEFORE MOUNTING.TO FINISH UP I CAULKED THE SPACER TO THE BODY . I WORKS WELL AND I THINK IT DRESSED UP THE OVERALL LOOK AND AFFORDS A LITTLE PROTECTION WITH IT HAVING A LOCK NOW. I DID NOT THINK TO TAKE ANY PICS OF THE "BEFORE" MY BAD. OVER ALL COST WAS ABOUT $50.00 WITH THE HATCH COVER BEING $40.00 WITH SHIPPING. JOE FROM DOVER Quote Link to comment Share on other sites More sharing options...
87 Oddy Posted March 9, 2017 Share Posted March 9, 2017 Looks good, nice solution to a common problem. I've got to deal with my fuel filler door that just broke at the hinge! Quote Link to comment Share on other sites More sharing options...
Derek up North Posted March 9, 2017 Share Posted March 9, 2017 It looks great, especially closed. Is there some reason I'm not understanding why you couldn't center it over the original gas cap location? Quote Link to comment Share on other sites More sharing options...
jmowrey Posted March 9, 2017 Share Posted March 9, 2017 Can you share a link for the place where you bought the parts for this? thanks Quote Link to comment Share on other sites More sharing options...
hunkaman Posted March 10, 2017 Author Share Posted March 10, 2017 hey derek, the reason for the "off set" is due to the size of the hatch cover (height and width), in relation to the dimensions of the fuel filler mounting collar. while researching the hatch covers, i found many sizes, but most were larger than i wanted. the one i bought was large enough to fit over the elongated or oval shaped fuel filler collar, but not so large as to look "goofy" after install. the method i chose to mount the hatch cover required the off set to maximize entry to the filler. is my explanation clear as mud ?? jmowrey--i know i have the link info, just need to find it. as soon as i do i will post it. thanks for you comments. joe from dover Quote Link to comment Share on other sites More sharing options...
hunkaman Posted March 11, 2017 Author Share Posted March 11, 2017 hey there jmowrey; i found the place i ordered the hatch cover from. it is, ADVENTURERV.NET. hope this helps. joe from dover. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted March 11, 2017 Share Posted March 11, 2017 JR Products 91122-A Polar White Key Lock Fuel Hatch https://www.amazon.com/JR-Products-91122-Polar-White/dp/B003VAY6JC Quote Link to comment Share on other sites More sharing options...
hunkaman Posted March 11, 2017 Author Share Posted March 11, 2017 HEY DEREK, your link to the item is a lot less than i paid. guess i need to research more before buying. thanks. joe from dover. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted March 11, 2017 Share Posted March 11, 2017 I did a quick search and saw them for between $25 and $38. My Scottish ancestors would come back to haunt me if I didn't shop around! Quote Link to comment Share on other sites More sharing options...
hunkaman Posted March 11, 2017 Author Share Posted March 11, 2017 hey there derek, i am sure you make your ancestors proud ! i try to make a dollar stretch enough that i can read the newspaper through it. being frugal seems to be a lost art on many i know. joe from dover. Quote Link to comment Share on other sites More sharing options...
