jhdbad Posted November 4, 2015 Share Posted November 4, 2015 I'm looking for the gasket that goes between the cab and the coach ... I have a 90 Sunrader shorty Any help appreciated Quote Link to comment Share on other sites More sharing options...
linda s Posted November 4, 2015 Share Posted November 4, 2015 The best solution I think anyone has found is white garage door seal http://www.stardoorparts.com/Garage-Door-Sandsto-Perimeter-Weather-Seal-2-Wide-p/DRSTOP2SAN.htm?gclid=CISm0t6q98gCFcVlfgod-McDAg Attached with contact cement and white silicone to seal the edges Example of how it looks. http://s46.photobucket.com/user/gfrasier/media/84%20Nissan%20Shorty%20Sunrader/DSC_0030.jpg.html?sort=6&o=10 Linda S Quote Link to comment Share on other sites More sharing options...
jhdbad Posted November 5, 2015 Author Share Posted November 5, 2015 Is the seal you have posted a uniform thickness? Is this the same product used on Gail's ? I looked at a garage seal at a local place but one side was much thicker ... would not be flexible enough to follow contours I like the look on the Sunrader. John Quote Link to comment Share on other sites More sharing options...
linda s Posted November 5, 2015 Share Posted November 5, 2015 Gail bought hers at Home Depot. Here's the Home Depot stuff http://www.homedepot.com/p/MD-Building-Products-1-in-x-30-ft-Vinyl-Garage-Door-Weatherstrip-03822/100190366 Linda S Quote Link to comment Share on other sites More sharing options...
jhdbad Posted November 5, 2015 Author Share Posted November 5, 2015 Thank you Quote Link to comment Share on other sites More sharing options...
jdfrost64 Posted November 6, 2015 Share Posted November 6, 2015 as for the sealer you should never use silicone to seal outer areas of a rv. use a non-leveling rv sealent. Quote Link to comment Share on other sites More sharing options...
linda s Posted November 6, 2015 Share Posted November 6, 2015 The silicone is not for sealing. It's to give a neat edge to the trim strip. RV sealant would look ugly. Linda S Quote Link to comment Share on other sites More sharing options...
jhdbad Posted November 7, 2015 Author Share Posted November 7, 2015 Ok bought the seal from Home Depot. Due to the messy job of caulk adhesive from previous owner need to use 2 seals side by side for added width. Would there be any advantage to spray some Great Stuff window/door type in gap between cab and coach? Quote Link to comment Share on other sites More sharing options...
linda s Posted November 8, 2015 Share Posted November 8, 2015 I don't know if that stuff breaks down. You want all the gasket material to sit on a solid surface with maximum adhesion underneath. Glue and spray foam don't sound compatible to me. Linda S Quote Link to comment Share on other sites More sharing options...
