Derek up North Posted May 2, 2012 Posted May 2, 2012 ... against a bunch of other tires we can't get over here. Even the Conti's are a different model from the Vanco 2s we get. http://infinityopony...omobil_ra08.pdf But they come out near the top. I don't know why there weren't any Yokos included. Quote
Sun King Posted May 11, 2012 Posted May 11, 2012 I've had mine on for about 3,000 miles now, they are pretty sweet. I am running the slightly taller 195s and wishing for a little more horsepower. I felt like I needed the extra load capacity since I am always rear axle heavy. Scale says 6800 total but haven't weighed individual axles yet. Tires are quieter than what I had before and sidewall flex is much less. I'll buy another set of them again. Quote
Derek up North Posted May 11, 2012 Author Posted May 11, 2012 I doubt you actually needed the extra capacity. The 185R14 is rated at 1764lb/tire (dual application). 4 x 1764 = 7056lb. So you'd even be good when doing wheelies! Difference in gearing is ~2.5%. Quote
Derek up North Posted May 14, 2012 Author Posted May 14, 2012 I never could find a table on the net, so I asked Hankook the following question:- "I'm looking for Load/Inflation Tables for Hankook RA08 tires in 185R14 size." This is the reply I got:- Thanks for the question. I was able to come across a load chart in a metric format. You'll just have to convert it for your needs. Inflation (kPa) 180 200 220 240 260 280 300 325 350 375 400 425 450 Single (kg)...... 490 520 550 580 610 635 665 695 725 755 785 810 840 Dual (kg)........ 470 500 525 555 580 605 630 660 690 720 745 775 800 Sincerely, Nicholas T. Coordinator Quality & Service Team Hankook Tire America Corp. 1450 Valley Rd , Wayne , NJ 07470 Tel : 1-800-HANKOOK (426-5665) X 616 Fax : 973.633.9980 email : nicholast@hankooktireusa.comNote: These numbers only go as high as 1600lb @ 50psi which corresponds to a Load Range C tire. I've sent Nicholas an email to see if he can find numbers for Load Range D. EDIT: I've added in BOLD the numbers sent by Nicholas for Load Range D. RA08_Catalog.pdf Quote
Derek up North Posted May 15, 2012 Author Posted May 15, 2012 More meaningful numbers (for those who don't talk 'Metric')! Quote
Derek up North Posted June 5, 2012 Author Posted June 5, 2012 I sent the same request to Yokohama for Load/Inflation tables. It took them 2 weeks to answer. Here's what they sent. Also includes values for 195R14. Sorry about the units! But they are the same numbers that Hankook uses. All the manufacturers follow the same standards. These happen to be published by JATMA (Japanese Automobile Tyre Manufacturers Association).Good morningThank you for your email and for your interest in our products.We were able to find an inflation table however, it is in kPa.We recommend you visit an authorized Yokohama dealer or contact the manufacturer of your motorhome to make sure you have the right pressure to support your vehicle.Isabelle ThemensCustomer Service ManagerTel : 450-963-7934Toll Free: 1-888-YOKO-TEL (965-6835)Fax: 450-963-3648Isabelle.themens@yokohama.cacustomerservice@yokohama.cawww.yokohama.ca Quote
