  • Hello Guest
  • Most Recent Three Posts
    • The exhaust and brakes are very minor problems for me to solve.  I can actually lift it on one of our 4 post lifts at work.  This is one of my 4Runners (my daily 1994) on there Friday night.  Perks of being a mechanic and having a seriously awesome boss!
      The brakes will annoy me, but warped rotors aren’t going to strand me. Still that will get sorted out pretty soon.  The exhaust…. I would say the same thing there if it wasn’t the 3.blow engine. Headgaskets and all that were done 7k ago.  So has it been leaking since then?  I have no clue lol.  I need to figure out where it is so
      I know if it’s ignorable, or at least drivable for now, or likely to cause a problem.
      Brakes are unlikely to cost me more than $200.  The exhaust, who knows. If it’s just a bad gasket, I have them on hand. If it’s a cracked manifold, I might replace them with headers.
      But my lack of thought put into those is simply a lack of concern.  It’s not hard to take care of. Unless I put headers on. They never fit easily hahaha!!!
      But item #3, the propane leak, does worry me a bit. But it’s just a problem to solve and then figure out what direction to go in.
      The very first job to take care of though is to get the rearview mirror and camera installed.  It has good side visibility, but zero rear view or backup.  Parts are sitting on the dinette.  I’m probably going to wait until I get it on the lift to finalize and run the wires underneath.
      I will get some interior pictures once I get that done and it cleaned up!   It’s pretty nice!
      Surprisingly it was actually pretty comfortable sleeping!   The upper front bunk I didn’t fit in very well with her and the little dachshund. I was uncomfortable.  So I setup the dinette sleeping spot.  My shoulder was acting up really badly and kept me up for a while. But I actually woke up with it feeling good and no achy back feeling really refreshed!
      Edited by thewanderlustking
    • Well, I got into the furnace and discovered a bunch of red dirt jammed into the combustion side of the fan. Not sure how it got in there as there was no evidence of mud daubers, but this camper did come from Arizona. Cleaned it out and the fan turns freely now - so now I have a replacement motor as a backup.
      Cheers,
      Marco
    • Nice summary - looks like you have a bunch of things to tend to!  I will be curious what you come up with for an awning, as many of the larger ones are designed for larger RVs with outside wall mountings of 6 feet vertical unimpeded space.  And smaller ones mounted above the door/windows will be way off the ground and often don't come with mechanisms to allow someone standing on the ground to operate it.
      I'd spend the time/money on the mechanical issues as dealing with a broken down RV on the road is 3X as expensive to tow and service.  It would be frustrating to write a very large check to deal with something like that, rather than a big Li-Ion battery, awning, etc. Best!
  • Forum Statistics
    13.3k
    Total Topics
    124.4k
    Total Posts
  • Gallery Statistics
    3k
    Images
    12.9k
    Comments
    365
