Most Recent Three Posts
Yeah, I could see that being a possibility. The crossmember where the lower arms mount shows the same in my notes - indicating that's so. But the front most crossmember (at front bumper) would require cutting and welding to mount those two angled "strut bars" and they may need cutting/rewelding as well. So, not for the faint of heart. It's also going to require an expensive fabricator that would be willing to take the measurements and customize things, and have a shop big enough for a Sunrader on a lift as well. Prior reading indicated this was a bolt on, and all the facebook folks claiming that was the case disappeared when I started asking finite questions on how they did it, and explaining measurements and bolt patterns that did not line up. If I start putting that kind of time and money into the front end, it will be a solid axle swap and 4WD conversion! Thanks for your input.
Am pretty sure you can adapt the entire 89-95 setup to the earlier 79-87 frames.
Crossmember and all with some work.
Edited by Ssunrader -
Nice to see it back running smoothly again, thanks to all that made it happen
Recently Browsing 0 members
Forum Statistics
13.3k
Total Topics124k
Total Posts -
Gallery Statistics
3k
Images12.9k
Comments364
