  • Hello Guest
  • Most Recent Three Posts
    • Ebay.  There is nothing special about that ECU or anything you need to do other than swap it out and plug it in.  It is a standard 3vz ecu for a 1989 etc pickup.  You could have it rebuilt too, but it is probably easier/cheaper/quicker o just replace it.  What you need to watch out for is go by the actual chassis year.  Look at the vin sticker on the door.  There is no special programming for the RV vs the regular pickup.
    • Here is just before you slide the axle shaft back in. You will see the new black rubber seal in the opening of the axle tube that many have disputed exists. Grease it well, grease the corresponding spot it rides on the axle itself. This way it will not run dry at first before the diff oil has been splashed onto it, which will lube it from then on. The seal separates diff oil from the wheel bearings, which are packed with grease.
      Then you slide the axle in slowly, supporting its weight, not dragging it heavily on that seal. Slowly because you will inevitably hit a sheetmetal guide in the housing with a hole in the middle that makes it easy to line up the far end insertion into the differential. Slam that hard with a heavy axle and it will pile drive the guide into oblivion, and a moments carelessness will require the diff to be removed to repair it. You'd have to be a numbskull to do it, but worth mentioning given the physics of that heavy axle shaft entering.
      Here it is buttoned up. Those 6 nuts are notorious for stripping their studs. Some factory manuals have an erroneous torque figure of 47lbs-ft in a chart. The correct is 26lbs-ft.  The wisdom is to stop at 22, as they get a spooky feel at 26 where you hit the torque. Nobody has reported them loosening. This is the exact axle from the 80 Series LandCruiser, so it is a well worn path. We have two of them and have put a combined 568k miles on them and I have repacked them each several times. The Cruiser forum has also addressed the error and is aligned with this. It is the only time I have ever recommended a non factory torque number.  New drums, though this one was stored out of its box so has patina!
      Tomorrow, my son and I will move it to store it for the winter and I am planning to answer a burning question.  How heavy are these axles?  I am astonished at how heavy they are and it won't be too much more than the foolie, but still...I am curious.  So I will get a weight for the forum. I don't know when I'll do the axle swap, but either late winter, or early spring.
      Informationally for future reference, the axles are 30 spline and I believe I also have a solution for the differential flange which is supposed to be a 27 spline (I'll confirm that).  I am going to pull this one out of the diff nose, and the drive shaft on my Sunrader, then mark the Sunrader's hole pattern on the flange and drill my own 4 holes out of phase with the current ones.  I looked at the links above, and measured my Sunrader shaft and they don't seem to have this one on their website.  Bonus on my plan is that like much of what I've done it will be free as I'll do it myself.  And the holes will be correct.  I once had a very expensive and rare antique Vanagon Syncro drive shaft rebuilt by a reputable shop.  They screwed it up and it vibrated like crazy.  Many times, I do this stuff myself because even machine shops are not what they once were. My son suggested this and it's a great idea. Stay tuned.
      Edited by IdahoDoug
    • I have been told by my mechanic that I need to rebuild or replace the original engine control unit/module in my 1991 Toyota Dolphin with V6 engine.  See photo.  Engine will run, but vehicle has to be driven like a manual transmission, starting out in first gear, moving into second, and then into third as long as there are no hills.  Back into first when stopped.  Even in first, Dolphin has a hard time going up the slightest of hills.  Any suggestions on getting the ECM rebuilt or replaced?  thanks.
  • Forum Statistics
    13.3k
    Total Topics
    124.4k
    Total Posts
  • Gallery Statistics
    3k
    Images
    12.9k
    Comments
    365
