AbleThought Posted March 30, 2016 Share Posted March 30, 2016 Hi all. I am noticing something and am not sure if there is a problem or this is how it's supposed to work but my deep cycle battery will not charge when I plug my 83 sunrader into power?? When I run the rader it does seem to charge. Is that how it's supposed to work? I'm still just using the basic setup.. Battery up front under the hood. Also it's a brand new battery. Quote Link to comment Share on other sites More sharing options...
Bob C Posted March 31, 2016 Share Posted March 31, 2016 Are you sure that you are getting power from the 120 volt supply? Check the voltage at one of the 120 volt outlets in the coach to see if the power is coming in. You may have a bad plug/cord or outlet on your supply. Quote Link to comment Share on other sites More sharing options...
