Ron k Posted November 4, 2007 Share Posted November 4, 2007 I'm looking to buy this 1987 camper can any anyone give me info, picts, comments, good bad ugly anything i'm very new to this type of motorhome please help me i need your input. dont want to make a mistake. http://cgi.ebay.com/ebaymotors/87-TOYOTA-I...1QQcmdZViewItem Quote Link to comment Share on other sites More sharing options...
Shoprat Posted November 4, 2007 Share Posted November 4, 2007 Howdy Ronk. Looks pretty good. Only question I would have about it is the plastic wrapping around the bunk mattress. That may be due to water leaks from the front area. I would ask the seller about that. Otherwise, as I said , it looks good. Good luck with it. Quote Link to comment Share on other sites More sharing options...
turtle Posted November 6, 2007 Share Posted November 6, 2007 looks like it has a couple of major dents in the top rear from being backed into things. Once the seams open up it is a constant fight to keep moisture out. Go look at it. Run a carfax report on the vin It is a "great white norht" unit so look for rust in the cab area and frame. Go look at it..... Quote Link to comment Share on other sites More sharing options...
bufbooth Posted November 6, 2007 Share Posted November 6, 2007 Nice looking rig, and I like the CB! Some suggestions / things to look for: 1) be sure the rear axle is a six bolt design, the five bolts are the older weaker axle and you do not want one. (this would be a deal killer) 2) check the tires for dry rot on the side walls and in the grooves of tread pattern, if cracking you need to replace. (you might be looking at buying 6 new tires at about $100 each). 3) check for soft spots around the windows on the inside, just use your finger, you should hit solid wood, if it gives in a bit, you have some water damage, not the end of the world, but a future expense. 4) check out the roof, if there has been past leaking problems you will usually see several patch job attempt to stop it. 5) take it for a drive, both in town and on the highway, make use you are okay with the cruising speed (probably in the 55mph to 60mph range) and the performance (or lack of), this one does have the 4 cylinder. 6) step on every spot on the floor for weak spots, which usually means water damage. Small areas you can live with, larger areas will need attention. Good luck, Dennis... Quote Link to comment Share on other sites More sharing options...
