kblake Posted October 22, 2007 Share Posted October 22, 2007 Hi we have a minicruiser, and a side dinette, with overhead wood cabinets, will up under the cabinets is a electric outlet, we plug our microwave in, that is working, but all the lights on the side are NOT working, we have check everything, any ideas? thanks Kblake Quote Link to comment Share on other sites More sharing options...
bufbooth Posted October 22, 2007 Share Posted October 22, 2007 Sounds like you blew a 12 volt fuse. Take a look at your 120 volt curcuit breaker box, there should be a small 4 inch by 4 inch panel that probably has two screws. If the writing has not rubbed off, it should state user accessable fuses, or something like that. Once you remove the 4x4 panel, you will probably see 2 or 3 in-line fuses, one of them is bad. Hope this helps, Dennis... Quote Link to comment Share on other sites More sharing options...
