kblake Posted October 12, 2007 Share Posted October 12, 2007 I am new at the toyota motorhomes, have wanted one for years, this is a good deal but have not seen it as of yet, what should I look for when checking this over, thanks everyone Kblake Quote Link to comment Share on other sites More sharing options...
bufbooth Posted October 12, 2007 Share Posted October 12, 2007 Hello, others should be able to offer you more/better advise, but I thought I would get it started: 1) be sure it has the replacement rear axle, it will be a 6-bolt pattern, be sure that that it is truely a 6-bolt axle and not an adaptor, I think the easy way to tell is that the axle should stick out 6 or so inches from the rim. If it is flush with the rim, it is the older axle in which you probably should stay away from. 2) take if for a ride at highway speeds, be sure you are okay with how it handles and that you are okay with the power performance. 3) Check the tires for spliting in the grooves. The tires could look new, but will be split/dry rotted. If you are counting on the six tires as part of the price and they are dry rotted, new tires will cost you about $100 a piece or more. 4) check for water damage around the windows and doors, just press the wood around them with your finger, it should be solid. Also, step on every part of the floor, any give is probably water damage. 5) check out every item inside, the heater, stove, oven, hot water heater, water pump, toliet air conditioning, and that water flows from every source. You probably will not be able to check the frig, takes too long, but ask if it works. 6) ask to see the service records of the engine, ask if the timing chain was replaced, if the head gasket was ever replaced, if the transmission was ever worked on, and when the last time the transmission was serviced (fuild change),l and when the rear axle was last serviced (fuild change), and when the fuel filter was replaced. Good luck, Dennis... Quote Link to comment Share on other sites More sharing options...
nighthours Posted October 15, 2007 Share Posted October 15, 2007 I was interested in the information you past on to the reader/new buyer for toy mini. I didnt have any idea about the rear axel problems. Ive had mine redone like 4 times now and the dealer never mentioned this issue to me.. Way thanks .I think the dealer likes my greenbacks. Boy do I feel like a doof. Quote Link to comment Share on other sites More sharing options...
