jomel Posted October 2, 2007 Share Posted October 2, 2007 Hello, thought that this first posting to the site would be maybe about finding a part, unfortunately this is not the case. We bought a '92 Winnebago Warrior at a good price with low miles and in great running shape. Interior was good and we questioned about patches on the roof and the seller said that yes there had been leak and he had it repaired. There was a bit of a sag in the ceiling, but we figured it could be old damage. A few days ago we had a good hail storm and the motorhome was out in our driveway waiting for it's covered home to be finished, the water pooled on the roof as it melted and we discovered drips inside in a few places. We took out the roof air and sadly discovered a badly damaged area of the roof and now have decided to take the roof off the majority and re-roof. We have had suggestions of replacing with 2x2's across, then 3/8 plywood and rubber roof. Any input in this unantiicpated project will be greatly appreciated. We just wanted to go camping!! Quote Link to comment Share on other sites More sharing options...
bufbooth Posted October 8, 2007 Share Posted October 8, 2007 My first thought is that the original roof design might of been on the weak side which added greatly to the roof failing, and that you do not want to repeat the original design. Instead of using 2x2 wood, you might want to look into using 2x2 or 2x4 (even if you need to lay them sideways (4 inches across and 2 inches up/down)) metal beams. I think you will get much more strength out of metal and you can still attach the plywood to the beams. I have always been a fan of metal (alumimun) roofs, you just need to seal the seams and vents, and they hold up (my opinion) better than a rubber roof. Dennis... Quote Link to comment Share on other sites More sharing options...
soft_hunter Posted October 14, 2007 Share Posted October 14, 2007 My roof is even more rooten. Previos owner cheated on me an covered with wallpaper. I am thinking about putting aluminum bars. Anybody know how to remove cabinets - some picture would be welcome. Thanks Quote Link to comment Share on other sites More sharing options...
