thepager5 Posted September 28, 2007 Share Posted September 28, 2007 (edited) This afternoon I replaced the exhaust manifold with a new one as well as all new gaskets. It is not leaking air anymore. However, as I was taking it to the gas station it suddenly started ticking - loudly! I sounded like the front of the valve cover. I pulled into the driveway and took the valve cover off. Everything sees to be attached correctly. No teeth missing on the timing chain or sproket. Where do I look next? Oil is clean up top - no shavings. I thought I read on another post about the valve cover being too tight. Bottom line - I have driven this engine about 1000 mile since purchase. (70K milage) There has not been any issues except for the exhaust gasket. Please help!!!!! Edited September 28, 2007 by thepager5 Quote Link to comment Share on other sites More sharing options...
thepager5 Posted September 28, 2007 Author Share Posted September 28, 2007 Hey there everyone - After reading for hours on-line about all of the different clicking noises under the hood, I decided that since this has never happened before, I would just start with the most obvious - the valve cover. I took the cover off - checked all the springs, nuts, arms etc. Nothing unusual. I then replaced the gasket and the two half moon gaskets at the ends. Re-installed and used new valve cover nut gaskets - these are reinforced w/ metal on one side (up) the other is cut to fit in and on the valve cover - I then (as per reply to another post) hand tighened and 1/2 turn w/ cresset the nuts. Making sure the gap was even all the way down the valve cover. Hooked all hoses back - changed oil and oil filter - unhooked and reattached the sparkplugs. Started it up and - NO MORE CLICKING!!!!!! I have driven it about 15 miles and took it out on the freeway for about three exits and 55 MPH. It is running great - thanks to the guys on youtube that posted the before and after of the engine that had the nuts too tight. This saved me from a trip to the mechanic and possibly lots of $$$$$$. Quote Link to comment Share on other sites More sharing options...
