econoline Posted September 7, 2007 Share Posted September 7, 2007 Hi Gang, I hope you can help me, as I've got a bit of an odd problem. I have a Toyota rearend that I've put into my 1961 Econoline. I've done a bunch of modifications and wanted the Dulley rear end for the truck with out using the big heavey U.S. ones. So now I want to hook up the E-brakes. At the backing plate of the rear end the brake cable bolts through. I need either an adaptor so that I can use a more standard cable or I need a custom cable made that has the Toyota end and the stock Ford on the other end. Thanks In advance. Dwight Quote Link to comment Share on other sites More sharing options...
