TikiShack Posted March 17, 2014 Share Posted March 17, 2014 My new to me Itaska MiniWinnie has an issue. The 110 volt circuits and distribution works fine, but the supply side is low - putting out only about 11.5 volts. The input voltage is good - 120v. This is not enough to keep the battery topped off, but will keep the lights going. Instead of replacing, I could buy a larger battery charger, and not rip out the old one. It would fit fine under the seat along with the old one. I could put the B+ line to the main output of the old unit, in parallel. A battery charger may cause radio interference, though. Anybody got a good idea or solution? Thanks Quote Link to comment Share on other sites More sharing options...
TikiShack Posted March 17, 2014 Author Share Posted March 17, 2014 OOPS! Found there is a ton of info on here under electrical section...but looking for the most plug and play option for the winnie! Quote Link to comment Share on other sites More sharing options...
