Pete1122 Posted October 5, 2013 Share Posted October 5, 2013 I keep finding new and interesting things in my 1989 Toyota Warrior, and a big thanks to this forum for helping me out! Can someone tell me what this red bulb looking thing is? It is hard to tell from the picture but I am under the motorhome looking up, the wires are attached to the holding tank. Mike Quote Link to comment Share on other sites More sharing options...
Vanman Posted October 5, 2013 Share Posted October 5, 2013 No idea and can't wait to see what it is for, I'll bet someone here will know. Quote Link to comment Share on other sites More sharing options...
waiter Posted October 5, 2013 Share Posted October 5, 2013 where is it located?? what is that thing with the straps. John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
rad wolfe Posted October 5, 2013 Share Posted October 5, 2013 isn't that the holding tank & straps? that red bulb unit ALMOST looks like 1 of the idiot lights in the data panel (inside) that shows fluid levels for the tanks. OK ....I don't have a clue ! Quote Link to comment Share on other sites More sharing options...
Derek up North Posted October 5, 2013 Share Posted October 5, 2013 Though it doesn't make much sense, but could someone have added a light to indicate when the holding tank is empty, to watch from outside while dumping? Like I said, it doesn't make too much sense to me, but then again I often do things that don't make much sense to others! Quote Link to comment Share on other sites More sharing options...
Pete1122 Posted October 5, 2013 Author Share Posted October 5, 2013 You are correct, it is the holding tank and straps. I assumed that this was a stock part of some kind. I tried to pull on the red plastic peice and it started to come apart so I left it pending info from you guys. Quote Link to comment Share on other sites More sharing options...
Pete1122 Posted October 6, 2013 Author Share Posted October 6, 2013 I pulled the red cap off and now I'm really confused. It appears to be a slightly soft rubber material almost like a glue stick. What is this thing?!? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted October 6, 2013 Share Posted October 6, 2013 Have you traced the wires to see what they're hooked to? Quote Link to comment Share on other sites More sharing options...
Pete1122 Posted October 6, 2013 Author Share Posted October 6, 2013 The wires appear to go right to the holding tank. Could this be part of the holding tank monitor system? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted October 6, 2013 Share Posted October 6, 2013 And is your monitoring system inside working OK? Quote Link to comment Share on other sites More sharing options...
Pete1122 Posted October 6, 2013 Author Share Posted October 6, 2013 Yes, working fine. Quote Link to comment Share on other sites More sharing options...
