bufbooth Posted September 2, 2013 Share Posted September 2, 2013 Hello All, I had to pull my rear axle on my 1990 Toyota Odyssey today, was installing new brakes and drums. After I put the axle back in I looked at my 1990 Toyota Factory Repair manual and for the six axle nuts (the ones with the cone washers), it stated 125lbs. Actually, it stated (340 km-cm, 125 ft. lbs, 33 N-m). There was no way these nuts (12mm) were going to handle 125lbs, so I did a conversion on the 340 km-cm and the 33 N-m and they came up to 24.3 and 24.6....so I think the correct ft. lbs should of been 25 ft. lbs instead of 125. Dennis... Quote Link to comment Share on other sites More sharing options...
Derek up North Posted September 2, 2013 Share Posted September 2, 2013 Good catch and thanks for passing on the typo. The good news is that the 1993 FSM found online shows 25ft-lbf. http://personal.utulsa.edu/~nathan-buchanan/93fsm/suspensionandaxle/34reara.pdf I'm not sure what's in the 1988 FSM. Quote Link to comment Share on other sites More sharing options...
