Vanman Posted July 23, 2013 Share Posted July 23, 2013 After much head scratching I realized the Toyota people figured since the front turn signals are mounted in plastic there was no reason to follow normal automobile convention in their wiring. Bulbs don't care but LED's do so I cut the wires behind the plug housing connector and reversed 'em. Now I've got nice bright left side turn lamps both front and back. I did follow the harness to the engine compartment and there it was the white wire with longtutudial black stripe and the 2 red bands crimped to a lug bolted to ground. In many years of working an cars, motorcycles, boats, I've never seen this before. But will sure check polairty on the bulbs not yet converted. vanman Quote Link to comment Share on other sites More sharing options...
Vanman Posted July 23, 2013 Author Share Posted July 23, 2013 I forgot to ask if anyone knows if the metal pins inside the connector on the wiring harness that plugs into the back of the bulb socket are removable ??? It would sure be easier to just swap 'em then cuting, splicing, crimping, taping up the harness. I have seen similar auto connectors that had a releasing tab for their removal, but could not find any way to do that on these, am I missing something ??? TIA vanman Quote Link to comment Share on other sites More sharing options...
