bufbooth Posted July 11, 2007 Share Posted July 11, 2007 Hello All, When I start the engine up, the check engine and the brake-on red lights will Stay on until I rev the engine up. While these lights are on, the radio, fan, and A/C does not get any power. This just started happening a week or two ago. I currently have the coach battery disconnected, if that matters. Any suggestions on what might be happening? Thanks, Dennis… 1990 Toyota Odyssey V6 Quote Link to comment Share on other sites More sharing options...
bufbooth Posted July 12, 2007 Author Share Posted July 12, 2007 Hello All, I connected the coach battery and my check engine and brake light now goes out as it should, so I think all is okay. Dennis... Quote Link to comment Share on other sites More sharing options...
superbeefirebird Posted July 12, 2007 Share Posted July 12, 2007 Just the same - keep an eye on the situation. I had both lights on as well, and eventually my battery stopped charging. Using a voltmeter, I discovered that the alternator wasn't putting out enough juice. It can take a long time for an alternator to 'slowly die'. 3 times I got stranded during a couple different trips. After changing the alternator, the battery charged fine and the battery light went out. But the brake light was still on. However, I just grabbed the emergency brake handle, pulled it out, and shoved it back all the way in. The brake light shut off and has been off since. This isn't to say you didn't resolve your problem - just that electrical is tricky with these rigs with aall the aftermarket stuff added. Good luck and happy camping! Quote Link to comment Share on other sites More sharing options...
Shoprat Posted July 14, 2007 Share Posted July 14, 2007 I had that happening even after I changed the alternator. Turned out to be the battery isolater ! I put on a relay and scrapped the isolater- no more problem. Quote Link to comment Share on other sites More sharing options...
