bufbooth Posted July 8, 2007 Share Posted July 8, 2007 I fixed my overhead window today, I had noticed it was leaking last week, looks like I caught the leak early, only some minor water damage, the plywood had one layer seperating. I used some Elmers (as in the Glue company) wood damage seal and repair product, seemed to do the trick, I brought it at Lowes (chain hardware store). I had some trouble with the putty tape, it does not seperate from the tape when it is above 80. I ended up putting it in the freezer for about 5 minutes and it got hard enough to be able to easily work with it. I started to check the other windows for water damage, and found one window, the overhead driver side window. It looks like it might have been leaking for a while, I have a 4 x 6 inch area that is a bit soft. I am 11 days from vacation, and fear that I may not have enough time, so I am going to delay the repair. I did seal the window frame last month, so I think I will not get any more water in, in the meantime. Dennis...1991 Odyssey Quote Link to comment Share on other sites More sharing options...
