kellig Posted September 15, 2012 Share Posted September 15, 2012 Hi--Has anyone tried using floor wax on the exterior finish? (I have a sunrader). Is liquid wax or paste wax best? Thanks. Quote Link to comment Share on other sites More sharing options...
toyboxII Posted September 15, 2012 Share Posted September 15, 2012 Hi--suggest you go the the Good Sam forum (www.rv.net) and read about using Red Max Pro floor finish. Users swear by it! I have used in on my '92 toyhome and get compliments on the appearance all the time. RMP comes from Lowe's, but they seem to be discontinuing carrying it. You can buy ZEP which is basically the same product at Home Depot. Users suggest you use the "wet look" product. Try it! You won't be disappointed. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted September 15, 2012 Share Posted September 15, 2012 Can't comment on the accuracy, but Red Max might not be available any more, so you'll have to look for ZEP. http://www.rvforum.n...p?topic=52608.0 I plan to try some ZEP (and Barkeeper's Friend) as soon as I find some. Quote Link to comment Share on other sites More sharing options...
ronsking Posted September 18, 2012 Share Posted September 18, 2012 My 87 Sunrader had the shine of a chalkboard when I bought it. I experimented with rubbing compounds, cleaners, waxes etc. with not much luck. After reading many polarized comments about Poliglow I gave it a try. The prep work is EVERYTHING. I think most of the negative comments I read were people who just washed their boat or vehicle and then applied coats of Poliglow. That would be a major mess. Use a Scotchbrite pad and clean/scuff it well first. After that it took 8 coats which just wipe on and dry in 10 minutes. It is basically like Mop 'n Glow but has more UV stabilizers. Anyways 3 years later and the shine is still on mine. http://www.poliglow-int.com/ Quote Link to comment Share on other sites More sharing options...
