keitholivier Posted April 26, 2007 Share Posted April 26, 2007 Has anyone had any luck with improving low end torque by changing out the camshaft ? I already will be replacing the exhaust system with a less restrictive system (including catalytic converter) and I am not after higher RPM, but more torque would sure help the engine hold a gear on an incline or into a strong headwind. Regards Keith http://cgi.ebay.com/ebaymotors/Toyota-22R-...103511660QQrdZ1 Quote Link to comment Share on other sites More sharing options...
86rader Posted May 2, 2007 Share Posted May 2, 2007 Good question. I would also be interested in something that gives a bit more oomph at 2-3K. Who cares if you loose something at 5K. My only concerns would be increased tranny heat issues and mileage. One other question. Is the 22RE an interference engine? If not, would a diffferent cam make it one? Quote Link to comment Share on other sites More sharing options...
kpf Posted June 6, 2007 Share Posted June 6, 2007 Keith: Try chancing your dist to a MARRORY UNILITE or something like it. You cand adjuts where you and how much advance (from 16 to 28 deg) and change your coil to one with internal resistor, I think the marrory is 29440 or 29441 with an output of 50kv not the stock 41kv. Quote Link to comment Share on other sites More sharing options...
knowltondata Posted June 6, 2007 Share Posted June 6, 2007 One other question. Is the 22RE an interference engine? Yes it is. Quote Link to comment Share on other sites More sharing options...
turtle Posted June 7, 2007 Share Posted June 7, 2007 (edited) Has anyone had any luck with improving low end torque by changing out the camshaft ? I already will be replacing the exhaust system with a less restrictive system (including catalytic converter) and I am not after higher RPM, but more torque would sure help the engine hold a gear on an incline or into a strong headwind. What I did to get more oomph was to replace the stock air intake/cleaner with a very non restrictive one and to have the ecu (engine control computer) reprogrammed. All in all this added around 30-35 hp to my V-6. I did this while I was in L.A. after purchasing the 91 Sunrader 18' V-6. Took the control computer directly to JET performance in Huntington Beach and they did the reprogramming while I waited (nice folks). The engine is no longer Calif compliant but hey... I don't live in Calif ;-) Both the intake and computer reprogramming can be purchased from Downey off road racing http://www.downeyoff-road.com/ The JET web site if you want to read more: http://www.jetchip.com/products.asp?pid=14...p;model=230#230 If you go with a reprogramming let them know it is for a motor home and you want more low rpm torque/power not high end power. Edited June 7, 2007 by moosepucky Quote Link to comment Share on other sites More sharing options...
86rader Posted June 21, 2007 Share Posted June 21, 2007 how much will I gain with a K&N filter on my '86 22RE? Can the computer on this model be reprogrammed? Quote Link to comment Share on other sites More sharing options...
turtle Posted June 21, 2007 Share Posted June 21, 2007 how much will I gain with a K&N filter on my '86 22RE?Can the computer on this model be reprogrammed? The folks that did the reprogramming said I would see an additional 30-35 hp increase with the programing they did.... BUT this was on a V-6 and the coach would no longer be Calif smog compliant (I don't care... I don't live in Calif). They also raised the shift points by around 800 rpm which lets the engine wind up a little more before shifting (auto trans) The computer on your 22RE can be reprogrammed, not sure of the HP increase on a 4 cyl engine but the more mods you make the more improvements a reprogramming will take advantage of. If you are thinking of getting the computer reprogrammed get all of your other mods done before you send it in as they will tune the computer to your engine modifications to optimize everything you have done. I can say that the difference in performance with the V-6 was very impressive. Driving back from Calif to the east coast I got between 12 and 16 mpg (depending on up hill or down, into the wind or following the wind) so I don't think that the mileage was greatly effected by the reprogramming. Like anything, if you put your foot into it you will not get good mileage but if you drive like a little old lady you can expect good results It does roar and scoot of you give it the peddle.... Quote Link to comment Share on other sites More sharing options...
